Sump Pump Check Valve Mystery - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2015, 12:06 PM   #1
Rewards Points: 302
I recently noticed water splashing back up out of the sump pump basin after the pump had been run. We had been living in the house for over a year and had never noticed that before although the pump doesn't run all that often. The water was coming out of the PVC pipe where it met the pump and the force was so great that it sprayed up and out onto the laundry room floor. So, I figured the check valve was bad and needed replaced....however, upon inspection, I do not see that a check valve was ever installed in the piping to begin with!
I thought that was a standard part of any sump pump installation. The piping runs vertically for 8 feet so I figured that would have been a given. Is there any chance it was not installed because the pump was supposed to be powerful enough to kick out the water with such force that little would come back down the pipe? Other than ignorance or laziness, would there be ANY reason not to install the check valve? Also, I don't know why it was not noticed before just recently....and the home inspector checked it out before moving in and it was not doing that.
Eagle One is offline   Reply With Quote
Old 05-11-2015, 12:38 PM   #2
DIY staff
Rewards Points: 7,174
It would not be surprising to find a pump without the back flow valve---I suggest you cut the pipe and install one----not having one causes early pump failure because it must pump out the same water every time the pump shuts off---
Old 05-11-2015, 03:41 PM   #3
Rewards Points: 302
I am definitely planning to install one. Researching different check valves reveals that plastic valves are typically not good and metal ones are durable. HD has one by Everbilt that claims the following: "the industry’s most durable check valve flapper. This is the world’s most reliable sump pump check valve."
Sounds great to me! haha....but is it true??
Old 05-12-2015, 07:27 PM   #4
DIY staff
How would you ever know if it is the worlds most durrable?
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
slamming check valve on basement ejection pump crankcase Plumbing 4 12-04-2011 08:38 PM
Help with check valve on recirculating pump joeq Plumbing 21 10-08-2011 04:24 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
