-   -   Sump pump check valve (http://www.diychatroom.com/f7/sump-pump-check-valve-62782/)
oldbear914 01-25-2010 04:40 PM
Where is the best place to locate the valve? Down by the pump itself or can it be located 5-10 feet above the pump?
Ishmael 01-25-2010 06:44 PM
The best place is down by the pump. If you have it a long way away, then every time it pumps out, there'll be a lot of effluent flowing back from where the check valve is into the basin again afterthe pump shuts off. It's not going to hurt anything, but you'll get a more complete "evacuation" if the check valve is closer to the pump.
The other possibility is that the pipe will hold a vacuum along that whole length up to the check valve (like holding your thumb over the end of a straw). In that case, your pump is going to have to overcome some excess resistance to pump out each time - could shorten the life of the pump.
oldbear914 01-25-2010 07:12 PM
That's what I was afraid that the answer would be. Guess I'm going to have to get down and dirty in the sump pit.
handy man88 01-25-2010 10:11 PM
Which is why they recommend drilling a small hole into the PVC pipe just after the pump connection.
rudolph58 01-26-2010 01:59 PM
just above the cover
coocoobe101 01-30-2010 03:02 AM
i usually install the check valve one to two feet above the lid---since you most likely are using a -Y-
connector to tie into the main pump discharge line--it would be a lot easier to work above the lid--
in the pit your always short on space--so make it easy on yourself--
always drill an 1/8 inch hole 3 to 4 inches above the bottom of the pvc pipe--
that is done to prevent air lock which eliminates pump failure--
putting a check valve under the lid is crazy--it makes no sense--good luck
