Old 03-12-2007, 08:26 AM   #1
Handyman62010
Sump Pump "BUMP"
Our sump pump runs about every 10-15 minutes here due to a high water table. At the end of the cycle there is a loud "BUMP" that I assume is coming from the anti-backflow valve closing shut with the water pressure above it. Checked the pipes and they are strapped really tight so there is no knocking against the floor joists.
Any experience out there muffling, insulating or eliminating this sound?
My wife is a light sleeper and I would be a hero if I could solve this one.
Thanks in advance!
Handyman62010 is offline   Reply With Quote
Old 03-12-2007, 11:59 AM   #2
Sump Pump "BUMP"
How old is the unit?
redline is offline   Reply With Quote
Old 03-12-2007, 03:15 PM   #3
Sump Pump "BUMP"
Sounds like a check valve located on a vertcal pipe. You could move the valve to the closest horizonal run of pipe. They also make spring operated check valves that may be quieter for you.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-12-2007, 06:03 PM   #4
Handyman62010
Sump Pump "BUMP"
Thanks for the replies.
I changed the sump pump and check valve. Valve was halfway between floor and ceiling, now it is in the pit with the pump. No more "BUMP"
Thanks again.
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Sump Pump Question cibula11 Plumbing 9 04-26-2007 04:28 PM
Sump Pump Help bolumenb Plumbing 4 01-22-2007 05:30 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
