Sump Pump Brand - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2011, 08:44 PM   #1
Rewards Points: 1,532
Sump pump brand
I believe I've seen Zoeller as the most preferred/recommended sump pump brand on threads on this site.
They've 4 models I'm considering:
MODEL 53
Cast iron switch case, motor & pump housing
Engineered thermoplastic base
Engineered, glass-filled, plastic impeller with metal insert
Stainless steel guard & handle
Bearing - lower & upper oil fed cast iron
MODEL 57
All cast iron construction
Cast iron impeller
MODEL 55
Bronze switch case, motor & pump housing
Bearing - lower & upper oil fed bronze
MODEL 59
All bronze construction
Bronze impeller
link at: http://www.zoellerpumps.com/ProductB...x?CategoryID=3
My current one is 18 years old and still working fine but I'm afraid that it will give out when you least expect it so time to replace it. We don't get much water into the sump pit but there is always some there. I guess I'm more interested in longevity than pumping capacity overall.
Any suggestions on these 4 (or another model or brand)?
TIA,
Bob
bob22 is online now   Reply With Quote
Old 08-23-2011, 09:43 PM   #2
Rewards Points: 352
I install mostly M53's. 1/3 hp. pumps a lot of water, last a long time.
plumberinlaw is offline   Reply With Quote
Old 08-26-2011, 10:49 AM   #3
So what do you do when the power goes out?
If you looking for the world's best sump pump, checkout the NexPump Ai5600 series. They will run under conditions when every other brand/system has stopped.
FisherGuy is offline   Reply With Quote
Old 08-26-2011, 09:56 PM   #4
Rewards Points: 352
when the power goes out a battery backup will run 6-8 hours and then stop pumping when the battery is dead. If on city water a water backup is the best way to go.
Old 08-26-2011, 10:07 PM   #5
Rewards Points: 1,088
People don't need to splurge on a generator if they don't want to.
They can just buy a high wattage inverter and just hook up to their car battery to provide temporary power to their primary sump or to keep their battery backup charged.
http://www.costco.com/Browse/Product...=1&topnav=&s=1
handy man88 is offline   Reply With Quote
Old 08-27-2011, 10:36 AM   #6
Update: I pulled out an 18-year old Zoeller M57 (once I got the crud off it I could read the label) and installed a brand new M57 and check valve. Both were identical (by chance) to what I bought off Amazon (delivery in 2 days for free!). Didn't have to cut any pvc; life is good! Nothing like a 15-minute swap with no problems, rare for me. Now, if the electricity stays on, Irene can do as she likes, at least my sump pump should not break down.
The Following User Says Thank You to bob22 For This Useful Post:
plumberinlaw (08-27-2011)
Submersible sump pump. Which brand to purchase????? needhelpplease General DIY Discussions 1 01-09-2010 03:29 PM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 02:01 PM
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 08:42 AM
Sump pump drainage question famdog Plumbing 1 01-05-2009 02:42 PM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 03:32 PM
