Old 11-23-2009, 08:03 PM   #1
Sump Pump Battery BKUP $900. ?????
Hi: I'm in the process of having drain tile and a sump pump installed.
Is a battery backup just a back up power supply or is it a seperate pump including a backup?
Can I just go out and buy a battery back up and plug my pump into it or is there more to it?
Any recomendations for a back up costs, etc. ?
I have to let the installer know tomorrow if I want to buy it from them - they want $900. !!!! YIKES!!!
Sorry for all the questions.
Thanks,
Tom
roztom is offline   Reply With Quote
Old 11-23-2009, 08:53 PM   #2
Civil Engineer
The definition of the words "battery backup" is literally a battery designed to supply backup power for a device. Therefore a battery backup by definition does not include a pump, float, or anything other than a battery which is typically charged off an outlet.
You cannot "just go out and buy a battery backup and plug your pump into it" unless your pump happens to be a DC pump designed to run on the voltage supplied by your battery backup. Most house sump pumps are AC, designed to run on 120 volts AC, and they will not run on a battery. If you purchase a battery backup with an inverter designed to convert the DC power produced by a battery to 120 volt, 60 cycle AC power, you can run your sump pump off that. The run time will depend on the size of the battery.
I don't understand your question about "Any recomendations for a back up costs, etc. ?". If you mean should you spend the money on battery backup, that depends entirely on the risk you are running if the sump pump fails during a storm and your basement floods. Only you know what you are planning to put in the basement. Consider the option of a backup generator, which would cost considerably more, but could power your house in the event of a power outage.
The whole question of backup is pretty complex, because there are many potential points of failure in the system. For example, if the pump fails, your battery backup means nothing. So should you have two pumps? If the float fails, your pump may not turn on, so should you have two floats? The battery might fail due to lack of charge, or deterioration of the cells - should you have two battery backups?
You really need to think through the entire system, and decide how much risk you are willing to tolerate. I have a sump pump in my basement, which has worked for 18 years. It is a Barnes industrial pump, cost about $400, but well worth it. My previous low grade sump pump quit in the middle of a storm, I got 18 inches of water in my basement. I do not have a battery backup, nor do I have a generator, my defense is that there is nothing valuable left on the floor in the basement.
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 04:48 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
