Sump Pump For Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2008, 01:45 PM   #1
Sump Pump for bathroom
My sump pump stopped working last week, I found the problem, the float switch, which I have too pick up. While I have it all apart, I want to know if there is any thing I can do to check out the pump. The pump is a FE Meyers, Ashland Ohio, Model MW50-1. according to the tag, it was installed in Sept. 99. It is made of cast iron. Can you give me an idea of how long I can expect it to last? If that is not too long, would it be a good idea to replace it now? And if so, can you reccomend a brand or type?
ri7425ck is offline   Reply With Quote
Old 04-30-2008, 01:10 PM   #2
I don't know anything about your exact model pump but Meyers makes a good pump. I have had pumps last 5-15 years depending on the quality. From now on I buy the best that I can afford.
Steve
sfixx is offline   Reply With Quote
Old 05-01-2008, 11:03 AM   #3
Thanks for the reply
I decided to replace to replace the pump. I have since finished that project and everything is working fine. thanks again!
