Sump Pump Basin / Pit Installation Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2014, 10:42 PM   #1
Rewards Points: 14
sump pump basin / pit installation question
Hello Everyone!
Have a quick question.
I am installing a sump pump pit for a pedestal pump. I bought Flotec 18 in. x 22 in. Sump Pump Basin from Home Depot. The pump will be used to pump out water that comes into the basement at different points and collects in one corner.
Now I dug a hole for the basin and is ready to install, but from what I am reading I need to put gravel under the basin and around it. Is it really necessary? I am not using the pump to prevent water from coming up, only to collect that ends up in that corner... What is the purpose of the gravel?
This is a solid 1/2 inch thick basin, no wholes in it at all and I was not planing on perforating it.
thanks for your input!
ipokrov
ipokrov is offline   Reply With Quote
Old 01-03-2014, 10:48 PM   #2
Rewards Points: 144
Yes it is necessary. IMO, the crushed stones help to filter out the mud, dirt and junk so it's not sucked in by the pump causing premature pump failure. I would follow the reccommendations and use it. Make sure you use big enough gravel so it doesn't get sucked into the pump as well. Just a thought. Stay tuned, others will be along shortly with more advice/ideas.
jmon is offline   Reply With Quote
Old 01-03-2014, 11:03 PM   #3
Rewards Points: 14
But this is a solid 1/2 inch thick basin, no wholes in it at all and I was not planing on perforating it. so the water wont have any mud, just what ever it picks up on the way to the pit
Old 01-03-2014, 11:25 PM   #4
Rewards Points: 144
ipokrov
Sorry, I have never set one up like that. I've always used perforated basins with gravel for proper filtering and drainage. Stay tuned and see what others reccommend.
Sump Pump discharge question hubaseball02 Plumbing 11 03-30-2012 06:56 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Sump pump float height dac122 Plumbing 8 12-08-2010 09:47 AM
sump pump question moisheh Plumbing 1 09-13-2009 03:14 PM
Sump pump installation moggi1964 Plumbing 9 04-25-2007 09:28 PM
