Sump Pump Base, Add Concrete Pad? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2008, 03:08 PM   #1
sump pump base, add concrete pad?
My sump pump well is opened to the earth at the base. I would like to make a concrete pad (with holes) or have the sump sit on a stone. I dont like having the sand in there. Any concerns raised by this?
micgall is offline   Reply With Quote
Old 12-06-2008, 03:38 PM   #2
I don't see a problem with this unless the holes get clogged.
Why not take some wire mesh used for stucco and make a tray for it to sit on. You could have some spikes to stick in the soil and push it in to where it is just above the gravel.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
