Sump Pump Backup System - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2013, 10:47 AM   #1
Rewards Points: 27
My mom had her house waterproofed on the exterior and the footer system backed up. The water proofing company recommended an interior sump pump. We would like a backup sump pump, but want super reliability. She has a Zoeller M53 sump pump in a crock outside, which will be used as a primary sump pump inside. My brother-in-law recommended the Big Dog Basement Watchdog backup pump, which is nice because it has AC and DC backup as well as a control system that alerts you if there is an issue... however, I've read bad reviews about the battery and some issues with the pump capacity being misleading.
I read a review on Amazon from an electrical engineer who said that he bought 2 primary sump pumps and powered them through a DC/AC power inverter with an auto transfer switch and hooked up multiple batteries in the case of a power failure. This sounds like an excellent idea and seems like it would be more reliable than any current backup system on the market. I am not an expert however and would like advice from you guys.
Is this a better option?
If so, should we have the water proofing company mount the secondary pump higher, so it only runs when the primary pump can't handle the incoming water or in the event that the primary pump fails?
Any comments/suggestions/alternative ideas would be greatly appreciated.
Thanks!
steve-19 is offline   Reply With Quote
Old 01-18-2013, 12:15 PM   #2
Water driven sump pump is another option.
If you have reliable city water, a water driven pump might be an option. I personally have this one: http://www.libertypumps.com/Products...p=76&s=23&c=14
Basement watch dog is battery driven backup one that is super popular. You can get it online and I think that Lowes and now Home Depot have them. The thing is that you have to deal with things like monitoring the battery etc. These usually have a heavy duty marine style battery that has to have battery acid added to it manually!
russiand is offline   Reply With Quote
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
Backup Sump Pump ed3120 Plumbing 5 12-31-2012 10:59 AM
Backup Sump pump battery question jazzyj Plumbing 4 09-09-2012 10:07 PM
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
