Old 11-10-2012, 10:05 AM   #1
Question
sump pump: Backup battery charge case. does it work?
I have a backup sump pump. It uses a Wayne 12-volt battery backup case with Solid State Controls.
Replaced battery a couple of years ago (deep cycle)....
back up pump isn't coming on..... but I really don't think the actual pump is bad.
getting ready to test battery,
BUT none of the lights on the front of my Backup Case are lit. Both "System Ready" and "Battery Low" lights are totally dark, even though charger is plugged into the wall.
I've managed to get the alarm to go off once.... but that's it...
is it possible for the batter case to be bad in some manner?
johnwalston is offline   Reply With Quote
Old 11-10-2012, 11:40 PM   #2
Does the solid state controls (board?) have a fuse? May have blown.
Advise battery condition after testing.
diyorpay is offline   Reply With Quote
Old 11-11-2012, 09:22 AM   #3
I don't know about a fuse..... not sure how/where to find it... doesn't look like there's a place to open up that panellll
but I can say I checked the battery and it is almost completely discharged........ only showed 2.5 volts on volt meter....... hopefully it is only a battery problem...... not a charger problem....
Old 11-12-2012, 08:23 AM   #4
What is the battery voltage with nothing at all connected to it?
What is the charger voltage when it is not connected to the battery>
What is the charger voltage when it is connected to the battery (and nothing else is connected to the battery and turned on)?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 12:09 PM
Pump battery backup for wood stove 1dude1 Electrical 3 12-12-2011 10:41 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 02:17 PM
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
