What type of pump could I use to backup my primary sump pump? I would like to avoid another sump pump to install in my pit
What about utility pumps, or other?
If you have a standard size pit and your current pump is at the bottom, you should have enough vertical room to create a kind of 'shelf' above your current pump. It would be the easiest method IMO. Just make sure you test it out maybe once a month b/c to me, a pump that sees regular use is much more reliable than one that sits unused for long periods of time.
Yeah, I know....I guess a float and contactor is something I could install...
I was also thinking about the Wayne ESP-25, which is a 12V sump-pump
I need a backup for 2 reasons:
1) Backup my primary pump in case it doesn't work anymore (but power is still on)
2) Backup my primary pump in case there is a power outage and I'm not home ot install the generator.
I'm kinda iffy on battery powered backup pumps. Odds are if you lose power its going to be due to a lightning strike from a thunderstorm. Depending on how much rain the storm drops & how long the power is out, you may or may not get screwed anyways.
Yes, I know...but it's better than nothing, at least for the first few hours
Like I said, it will give me time to react (unless I am far away of course)
And it will also backup the primary pump if that one was faulty
Other than that, the only other solution would be a water operated pump (venturi), but I am not convinced !!!!
I would still opt for a gas generator and an extension cord. Have a replacement pump boxed just in case it gets fried due to lightning strike.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
