Old 07-01-2007, 07:05 PM   #1
Question
sump pump
1. is this a good resource guide for DIY sump pump installation ?
http://www.diynetwork.com/diy/hi_plu...338412,00.html
2. if not, do you know one ?
3. the above instructions call for the waste to be taken above the pump and outside the house ? i am installing one in a living basement and was wondering if it is okay to have it dispose into the sewer main ?
4. since my basement apt. will have three step levels (entry, step down to main, and then another step down into the bathroom), it makes sense to have the pump in the bathroom. is this, for some reason, a bad idea ?
thanks,
- a
Old 07-01-2007, 07:27 PM   #2
Contractor
Dan101's Avatar
sump pump
a
Before you get started, please be sure you know all the differences between a sump pump and a sewage ejector pump. They are not the same.
The link you referenced is instructions for installing a sump. Sump is designed to pump groundwater out of your basement. If you are installing a new bathroom, you will want to install an ejector pump. Ejector is designed to grind and pump solids out of your basement. Installation is very similar but there are some important differences.
Yes, if you are pumping waste from your bathroom it has to discharge into sewer. It also requires venting.
Yes, pumps should always be in the lowest level in your basement. Good luck with your project.
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Dan101 is offline   Reply With Quote
Old 07-01-2007, 07:33 PM   #3
sump pump
Old 07-01-2007, 08:28 PM   #4
concretemasonry's Avatar
sump pump
A sump pump discharging ground water from drain tile cannot be discharged into a SANITARY sewer line (the opposite of a sewerage ejector pump). It should be discharged to the exterior of the house and it may be riuted to a STORM sewer.
For a sump pump, install a check valve just above the pump in the discharge line. This will eliminate short cycling and extend the life of the pump.
concretemasonry is offline   Reply With Quote
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Sump Pump Help bolumenb Plumbing 4 01-22-2007 05:30 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
