Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 04:30 PM   #1
sump pump
Hi there i have a goulds sump pump, it has a electrical box by the fuse panel with buttons that say silence horn rest and test buttons there is also a red light on that says high water level about 2 weeks ago the light was on but it was dimm now it is bright if i put the button on horn reset it rings also conneted are 2 sensors that go to the alarm system any ides the pump model is pe41p1 aprox age 2 years
Thanks in advanced
EGuzzi is offline   Reply With Quote
Old 06-16-2010, 05:18 PM   #2
You didn't mention it, but did you look inside the sump basin? Is the water level up to the top? If the high water alarm is going off, that tells me the water level is "high" and the sump pump is not turning on.
The Engineer is offline   Reply With Quote
Old 06-16-2010, 05:41 PM   #3
there are to areas the one beside the water heater has an opening and i can not see any water (that is the one with the alarm sensor and the goulds electrical box wire and it has a vent that goes out side the other one only has the house alarm sensor i can not see inside this one but i can hear water drops hitting the water
Old 06-16-2010, 07:50 PM   #4
An old Tradesmen
Rewards Points: 7,830
Moved to plumbing forum.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
