Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2009, 04:40 PM   #1
Sump Pump
Our sump pump will not turn off after it drains all the water from the well. Can someone tell me how to get it the shut off without having to turn off the breaker.
jdpc1 is offline   Reply With Quote
Old 08-11-2009, 04:46 PM   #2
Rewards Points: 1,088
Is the float stuck?
Or, unplug it.
handy man88 is offline   Reply With Quote
Old 08-11-2009, 06:19 PM   #3
Rewards Points: 1,580
Might need a backflow valve (can't think of proper name right now) if when it shuts off the water in the exhaust pipe runs back into the sump and reactivates the pump.
bob22 is offline   Reply With Quote
Old 08-11-2009, 09:17 PM   #4
Originally Posted by handy man88 View Post
Is the float stuck?
Ditto
http://www.sump-pump-info.com/float-switches.html
I don't see what else it could be.
Old 08-12-2009, 09:07 AM   #5
Rewards Points: 1,512
If the volume of water still in the outlet pipe when the pump shuts off is great compared with the working volume of the pit then you will get more frequent pump turn-ons.
1. Provide a bigger pit.
1a. Does the existing pit allow a higher level before the pump starts and/or a lower level before the pump stops?
2. Use a thinner outlet pipe (caution, this can overload the pump)
3. Can the routing of the outlet pipe be changed so there is less net height to which the water must be raised before it flows by gravity to its final destination. This means less water left behind in the outlet pipe.
While a check valve can help, it needs to be inspected periodically for debris holding it ajar that would defeat its purpose.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 12:21 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
