Old 04-20-2009, 10:56 PM   #1
Sump pump
I need to replace my sump pump. I currently have a Zoeller 1/3 hp. Any suggestions on a good brand. I can't really find any ratings on the net.
First timer1 is offline   Reply With Quote
Old 04-21-2009, 07:09 AM   #2
Sump pump
What is wrong with the Zoeller??
Old 04-21-2009, 07:47 AM   #3
Sump pump
zoellers are good pumps stick with it
al's sewer is offline   Reply With Quote
Old 04-21-2009, 09:05 AM   #4
Concrete & Masonry
Sump pump
One more vote for Zoellers, or Jim Murray Pumps, if available in your area.
jomama45 is offline   Reply With Quote
Old 04-21-2009, 11:41 AM   #5
Sump pump
My pump seems to have "burned" out. I noticed it was running for a long time. When I went to check on it later it would not come on.
Old 04-23-2009, 08:26 PM   #6
Sump pump
I will look into the M53.
Old 04-24-2009, 11:37 AM   #7
Sump pump
your float valve more than likely had something on it to stop it from functioning properly. If it happens again check your float valve and make sure thier is nothing obstructing it.
Old 04-25-2009, 10:41 PM   #8
Sump pump
I actually did check the float. I pulled the cover off the pit and also checked the switch that the float is attached to. No luck in getting it to run again.
Old 04-26-2009, 11:02 PM   #9
BULLETflight7's Avatar
Sump pump
Goulds WS0511BA are 1/2 hp 115v and are good all around cast iron pumps with 2" discharge and piggyback float. (great solids handling pump)
Tsurumi makes an awesome pump as well, for water or effluent only, no solids. We replace alot of zoellers with these two pumps, depending on the application.
-Jason
BULLETflight7 is offline   Reply With Quote
Old 04-29-2009, 10:59 PM   #10
Sump pump
I have not heard of either of those pumps. I will look into them to see if they are available here. Thanks
Old 05-02-2009, 04:44 AM   #11
JDC
Plumbing Contractor
JDC's Avatar
Sump pump
Zoellers are damn fine pumps. I also use Stephens from time to time.
LMAO....Gotta LOVE BULLETflight7's avatar!!!
JDC is offline   Reply With Quote
Old 05-04-2009, 10:18 PM   #12
Sump pump
Thanks for all of the great info. I went with the Zoeller M53. Actually, that was the model I had to replace.
More On This Topic
About DIY Plumbing
About DIY Plumbing by Shawn Kenny
Before tackling plumbing problems at home, make sure to get the proper tools and mindset for the job at hand. Avoid making huge mistakes when fixing plumbing issues without professional assistance with help from a plumber and HVAC tech in this free video... Read More »
DIY Home Security Tips
DIY Home Security Tips by expertvillage
Learn how to protect your personal properly against theft in this free video clip from an expert locksmiths. Read More »
Learn about terminating plumbing in a room you plan to remodel in this free do it yourself video on home remodeling. Read More »
There is no reason to throw out a chair because of a loose chair rung. Fixing a loose chair rung is quick and easy to do. It is a great skill that allows you to fix flea market finds and garage sale cast-offs, or just to prolong the life of your existing... Read More »
Home improvement ephemera from the 1950s is one of the most popular collectibles because of the change in women's roles. Discover more about collecting home improvement ephemera with expert tips from an antique store owner in this free video about... Read More »
Exterior grade sump pump Jeeper1970 Plumbing 8 07-03-2010 10:23 AM
Sump pump pit water level --- problem de12 Plumbing 41 04-09-2010 11:07 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
