Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2012, 06:04 AM   #1
sump pump
Hi DIY Tam my sump pump is constantly running water what does that mean.
gailhart is offline   Reply With Quote
Old 12-21-2012, 06:50 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... Sounds like it's Workin'....
Also sounds like yer home has a leak,...
What's the grade around the house,..??
Any idea just where the excess water is comin' from,..??
Old 12-21-2012, 09:45 AM   #3
Rewards Points: 13,446
Little vage on the question.
Are you saying there's non stop water running into the pit and the pump never shuts of?
If so you have a major issue with a plumbing leak under that slab.
Or is the pump just not shutting off with the pit empty.
If so the float is stuck, hitting agiant the side of the pit or the switch is bad.
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
sump pump "pit falls" bubbler Plumbing 6 03-09-2011 08:45 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
