Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2008, 02:12 PM   #1
Sump Pump
My basement just recently flooded (after a thaw of 16" of snow and a three hour torrential rain) - only about 1 1/2" of water luckily - 'cause another neighbor had 8" and lost their furnace....The basement is divided into two areas...on side is finished with a floating floor and carpeting (all has been removed)- with a French drainage system and large well and sump pump....the sump/French Drain were installed before I moved in - so after checking the sump which was full and checking the pump - turns out the outlet is dead....the outlet is not grounded and was part of the original 60 year old home (all behind the wall which is now exposed - sheetrock had to be cut 2' all around the room)....anyway I am going to run a dedicated line to the sump - question is does it have to be GFI protected? - I would assume so but some others have said No...I could also install a GFI breaker I suspect if needed?....I live in NY....
Thanks,
Rick
Rick Bruner is offline   Reply With Quote
Old 01-12-2008, 04:18 PM   #2
Send a message via AIM to Marlin
You may get your answer here but I'd post this over in the electrical forum.
Marlin is offline   Reply With Quote
Old 01-13-2008, 08:54 PM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Actually it should NOT be on a GFCI. You don't want a nuisance trip to lead to flooding.
Brik is offline   Reply With Quote
Old 01-13-2008, 09:12 PM   #4
Electrician
I dont know what a nuisance trip is, but in 08 the code will only except GFCI protection.
chris75 is offline   Reply With Quote
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 08:32 PM
Sump Pump Spraying Water lancoll Plumbing 1 12-12-2007 02:18 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 08:47 PM
Sump pump re-hab mpking Plumbing 1 11-07-2007 11:29 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
