Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 12:15 PM   #1
Sump pump
Can you attach a garden hose to a sump pump?
robbiebrownkw is offline   Reply With Quote
Old 01-19-2012, 12:17 PM   #2
MarginallyQualified
Rewards Points: 2,464
I suppose... but why would you want to ADD water to a sump pump?
Old 01-19-2012, 12:20 PM   #3
Sump Pump
I do not want to add water I want to use the hose to take out the water!
Old 01-19-2012, 12:22 PM   #4
Rewards Points: 13,732
Depends what size outlet is on the pump?
What are you trying to do with it?
There's a reason why larger cap. pumps come with larger outlets. Try standing on a garden hose and turn it on.
If the pumb can not pump to full flow it will over heat and far less water will get pumped.
Old 01-19-2012, 02:02 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,... I've done that to bilge out my boats durin' the summer...
Only problem is the sump pumps like bigger discharge hoses, 'n they labor quite abit with only a garden hose...
Bondo is online now   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
