Old 11-01-2012, 07:05 PM   #1
Question
Sump pump: 1 1/2 connection to 1 1/4 PVC pipe
I have to replace my sump pump. I notice that it currently has a Wayne 1/2 hp sump pump. (it was professionally installed 10+ years ago, I think.) Anyway, I plan to buy another Wayne 1/2 hp sump pump and do it myself. But I noticed that the PVC discharge pipe that was installed is 1 1/4 inch pipe. Yet the pump connection I see advertised is 1 1/2 inch. I am going to have to buy check valve, too. but my question is: will this work with 1 1/4 inch pipe? I sure don't want to have to replace that pipe if necessary.
and how do I make it work? what parts do I need to buy?
johnwalston is offline   Reply With Quote
Old 11-01-2012, 07:12 PM   #2
the connectors that come with most check valves will work with 1-1/4 or 1-1/2 pipe.
The Following User Says Thank You to DannyT For This Useful Post:
johnwalston (11-01-2012)
Old 11-01-2012, 07:26 PM   #3
so, I just put 1 1/2 inch pipe into the sump pump, run it up to the check valve and have 1 1/4 inch pipe coming out of the check valve? and that will work without any problem?????????
Old 11-01-2012, 07:27 PM   #4
To decrease or increase in size a swage is one of the best options for flow and it's too bad they aren't more readily available. They can be found if one knows where to look but in PVC is where it seems to be impossible.
Sump pump: 1 1/2 connection to 1 1/4 PVC pipe-swage.jpg
Fairview is offline   Reply With Quote
The Following User Says Thank You to Fairview For This Useful Post:
Old 11-01-2012, 07:44 PM   #5
call me E
TheEplumber's Avatar
put a 1.5"x1.25" galvanized bushing in the pump outlet.
The Following User Says Thank You to TheEplumber For This Useful Post:
Tags
check valve, discharge pipe, sump pump
Sump Pump Basin install, existing rough sump hole. McSweny1103 Building & Construction 3 02-12-2012 03:45 PM
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 09:05 AM
Sump pump float height dac122 Plumbing 8 12-08-2010 09:47 AM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
