Sump Pit Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2011, 10:46 AM   #16
Two more questions. Where do you think that clay pipe origonally went? Tied into the pipe that runs through the middle of the house and out to street sewers? BTW thanks for your time. Can I use a coregated pipe, It will only be about 5-7 inches long to connect the drain pipes to the well? None of the pipes line up well to use PVC, I kind of need the flexablity.
tarq182 is offline   Reply With Quote
Old 07-11-2011, 06:36 PM   #17
DIY staff
Rewards Points: 7,174
Flexible corrugated will be fine-- It's probably not functioning any more--however it will direct water under the slab into the pit--so that's worth the effort to make the connection.
Sump pump capacity question Davidb6 Plumbing 6 02-22-2011 09:17 AM
Sump pump drainage question famdog Plumbing 1 01-05-2009 01:42 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
