Sump Pit Overflow Backup - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2013, 12:39 PM   #1
sump pit overflow backup
My house is situated on a lot with a walk-out basement and down sloping back yard. Could I build a tub like structure above the existing sump well with a drainage pipe running out the back foundation wall (above grade)? This would contain potential overflow and allow it to run outside naturally.
defab is offline   Reply With Quote
Old 03-13-2013, 02:56 PM   #2
Rewards Points: 1,418
It is possible that (using trial and error) you keep getting water seeping up onto the far side of the basement floor unless you keep the level in the sump pit below the level of the 3 inch or 4 inch drain pipes that empty into the pit. In that case you will never get the level high enough to flow out over the bathtub like structure that you built atop the pit.
Each time you want to change the float settings on the sump pump, allow ten days before drawing any conclusion as to how well it worked.
Old 03-13-2013, 03:56 PM   #3
sump well overflow
That's true...I never thought about the overall water level around the house. I guess it would work (in theory) if the basement foundation and walls were truly waterproof.
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 11:42 PM
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 01:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 02:55 PM
Sump Pump Backup Battery Error? dajonx Electrical 11 09-29-2011 12:10 PM
Receptacle for sump and backup sump howard.wheaton Electrical 2 06-27-2009 11:39 AM
