Sump Pit Not Filling.with Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2013, 09:31 PM   #1
sump pit not filling.with water
we just had a rain that lasted all day and my neighbors sump pump.is going off frequently. I decided to check mine out and the pit is dry as a bone. I have lived in this brand new house for over two years and it has never filled. my neighbors grass is greener where his dumps outside because his fills frequently. any ideas?
jdoubleu is offline   Reply With Quote
Old 04-22-2013, 09:44 PM   #2
Rewards Points: 13,458
And why would this be a problum?
Is your basement wet?
Proper grading, better drain tiles, land higher the the guy next door, differant landscaping, better layout of gutter drains can all have something to do with it.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
fetzer85 (04-23-2013), jdoubleu (04-22-2013), oh'mike (04-22-2013)
Old 04-22-2013, 09:49 PM   #3
DIY staff
Rewards Points: 7,174
I have gone for 4 years without my pumps running---then ,when the nearby river hits flood stage--the water table will rise and the pumps go non stop for a week---
Relax and be glad-----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 04-23-2013, 07:48 AM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
French drains & sump pumps are often installed in new construction, mainly because we're getting smarter. It's so much easier to install systems like that when the house is being built vs. waiting until your basement gets wet. Anymore it isn't even a question of whether or not you 'need' it, it's just an extra precautionary measure. You should be glad you have it AND glad it's empty. 100yrs ago they didn't install systems like this and also didn't waterproof their foundations. Result? More often than not, wet basements. Floors cracking from hydrostatic pressure allowing water to seep through...unsealed foundation walls either filling up w/ water or also cracking and allowing water through. Thankfully we've learned a lot in the last 100yrs which means you should have a dry basement for a very very long time.
On a side note, our sump pump runs multiple times a day regardless of whether or not it rains. Our neighbors on either side of us both have pumps that rarely run. It's just one of those things...maybe an underground spring, different dirt types...hard to say for sure. For good measure though I would suggest filling your pit w/ water to make sure your pump is working should you ever need it.
fetzer85 is offline   Reply With Quote
Old 04-23-2013, 11:25 AM   #5
Concrete & Masonry
Rewards Points: 548
Any chance you have a fully exposed/walk-out basement? If you do, the draintile generaally run off at grade rather than collect in the sump crock. "HERE", sump crocks are mandated by code, even though some homes will never have any water, or a pump for that matter, in them.......
jomama45 is offline   Reply With Quote
ground water sump pit water flow surayabay Plumbing 3 04-13-2013 11:25 PM
Water in Basement. One last Question. daltinator Building & Construction 8 01-25-2012 11:59 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
