Sump Drain ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 12:27 AM   #1
williamwallace's Avatar
Sump drain ?
I've set up crawl space drain to run out side of house. What or how should I deal with water that is being drained?
williamwallace is offline   Reply With Quote
Old 11-18-2012, 12:57 PM   #2
Rewards Points: 1,532
Make sure it runs downhill .
What part of the country? Freezing temps etc...?
bob22 is online now   Reply With Quote
Old 11-18-2012, 05:06 PM   #3
We are in Washington state, I have it running down hill.
I thought of draining the sump water into the septic system, not sure?
Could drain into a buried five gallon can with rocks in it?
Old 11-19-2012, 07:22 AM   #4
Rewards Points: 1,418
Get the water away from the house.
If you can put a drain opening at the bottom of the pit (sump) and unlimited amounts of water water will exit there and not back up then so much the better. Otherwise you will need a sump pump.
Do not drain into the septic system.
A 5 gallon dry well away from the house and filled with rocks is not sufficient because it will overflow in no time since the amount of space for water is much less than 5 gallons. Ever notice that when you buy a soft drink with a lot of ice in it you don't get much drink?
Psst! In order for water to flow by gravity out of a drain in the pit to daylight, the ground surface must slope down away from the house at a greater slope.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Crawlspace perimeter drain and sump pump needed? ncrango Building & Construction 1 03-04-2012 08:35 AM
Sump pump drain Shred180 Landscaping & Lawn Care 2 01-01-2012 11:55 AM
sump pump crock with no pump or drain installed mauragolf2 Plumbing 5 06-25-2011 09:30 AM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
