Sump Discharge Pipe(copper) Exits Mid Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2013, 02:56 PM   #1
Rewards Points: 99
Sump discharge pipe(copper) exits mid wall
It exits at around waist height and is drilled through the block. Any idea where a setup like that would drain to? It is probably around 3.5' underground still at that point.
dwcopple is offline   Reply With Quote
Old 04-24-2013, 03:22 PM   #2
MarginallyQualified
Rewards Points: 2,464
Into the yard. Maybe out to the street or even the city sewer line.
Look at your curb for an "extra" hole.
If you're really concerned borrow someone's metal detector.
Old 04-24-2013, 03:27 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Hard to say w/o digging it up to find out. I imagine it doesn't just drain to daylight somewhere? Short of that, it could be tied into a runoff system if your city has sewer & runoff separated. If you have septic then you can rule this one out. It could also be draining to a dry well which is more or less a holding tank with gravel inside buried in the yard. Could be tied into perforated corrugated plastic or pvc to drain out in the yard but that's doubtful if your sump line is copper - I would think they would've replaced it w/ plastic at that point but you never know. It's not supposed to be tied into sewer but that doesn't mean it isn't.
Long answer short - if you can't physically see where it exits and can't ask the person who did it then that kinda just leaves the digging it up option.
fetzer85 is offline   Reply With Quote
Old 04-24-2013, 03:57 PM   #4
Rewards Points: 99
the exit is at the rear of the house so that eliminates to the curb or sewer. Long ago, our houses were septic systems but have since been converted to sewer. I imagine it probably just goes a ways out into the ground, but I'd still like to know for sure.
Old 04-24-2013, 04:08 PM   #5
Concrete & Masonry
Rewards Points: 470
My house had one through the wall when I moved in. Also had one above grade for the winter months when the in-ground pipe froze, I assume. I lowered my pump substantially, which caused it to run for a few weeks almost non-stop. That huge amount of water created a wet spot in the gravel driveway, which soon led to water bubbling out of the ground. When I dug it up, it became clear that it was tied into an old field drain tile, which had become clogged. I guess the point is you never know where it's going for sure until you do a little digging......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
concretemasonry (04-24-2013)
Old 04-24-2013, 04:45 PM   #6
Rewards Points: 99
yeah, that's not gonna happen. I have a deck out back there. How far away is a typical septic/leaching field from a house?
Old 04-25-2013, 06:29 AM   #7
Rewards Points: 1,418
You do not want to run the sump pump outlet to a septic tank system!
That can cause an overload and drain backup.
Old 04-25-2013, 07:13 AM   #8
Rewards Points: 99
I am not, I have no idea where it is going. I thought you guys might know.
Old 04-25-2013, 06:26 PM   #9
Rewards Points: 1,692
Run a hose into it and see what gets wet outside.
Old 04-25-2013, 07:24 PM   #10
Concrete & Masonry
Rewards Points: 470
Try water dousing:
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
Sump pump discharge set-up moneymgmt Plumbing 23 02-26-2012 12:46 AM
Configuration of 2 ball valves on Sump Discharge Line chsitko Plumbing 3 11-25-2010 10:13 AM
sump pit/pump questions aliasoink Building & Construction 8 03-03-2010 12:41 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
