Sump Completely Dry But Found Water In Basement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2011, 09:15 PM   #1
Sump Completely Dry but Found water in basement?
We had a torrential downpour today (living in Central IL), and they briefly blew the sirens so my family and I went downstairs. I was shocked to see some water in one end of the basement (unfinished basement). It must have been a decent amount at one time as it appears to have covered the floor from wall to wall, but did not get into the other half of the basement.
I checked the sump, it was 100% dry... Has been dry lately, and even the floor of the sump was dry. The water was sitting around the utilities... But completely dry around water heater, and the AC drain PVC runs right over to the drain in the floor, which was also completely dry. The water is underneath the furnace, but with the AC drain appearing to work, I can't figure what water would come from it. I went out and checked, all of my downspout extensions are okay... And the weirdest part about that would be that the utilities are on the wall of the foundation with garage on other side of that wall. No flood in garage or around garage, so doesn't seem like it'd be the gutters in any case.
Any ideas? As I go through elimination it starts to feel like seepage, but I can't figure what would cause seepage with the sump dry... since that'd seem to indicate water level below sump (which is below the floor).
thefish7 is offline   Reply With Quote
Old 08-08-2011, 10:15 PM   #2
Rewards Points: 1,418
Perimeter drain pipe(s) may be clogged, typically with soil that gradually washed in over the years.
These perforated pipes should have a free flow to the sump.
While the empty sump would mean that the ground water level is below the floor level there, the water level could be somewhat higher 20 feet away from the sump.
With the perimeter drain pipes clear, the ground water level all along where they run should be no higher than the pipe interior.
Old 08-08-2011, 10:16 PM   #3
Okay, how could I look for that, and what kind of remedial action could I take?
Old 08-09-2011, 12:13 AM   #4
I'm a little unclear on the situation. Is there water around the furnace? If yes, improperly running equipment could be the problem. Especially with the humidity from recent days. I had a basement with wicked, flood like symptoms: the cause was the A/C not running the way it should. My best advice would be to monitor the situation: observe when you see the water.. the weather, etc.... and go from there.
brokenhammer is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Basement flooding problem found problem just need help fixing it. tayous Flooring 2 03-30-2010 09:55 AM
Advice for a novice: Mold and water damage in basement xoxJanette General DIY Discussions 1 12-29-2009 07:54 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
