Sump Basin Fun - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2012, 09:11 PM   #1
Amateuralex's Avatar
Rewards Points: 270
Sump basin fun
I've been in this house for 8 months. Built in 1979. Good house but lots of work. I wanted to install a lid for my sump and after doing some research I thought I'd just replace the basin and pump and get a matching lid that will look nice. The sump setup currently works fine. It has what looks like a cast iron basin in it. I thought it might be tough to move but it won't budge even slightly. Any ideas?
Amateuralex is offline   Reply With Quote
Old 08-22-2012, 09:24 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 900
Are you truing to replace the sump basin? Good luck with that
Build a lid to match
Old 08-23-2012, 07:04 AM   #3
Rewards Points: 270
OK I thought so, thanks. Plywood and a jigsaw ya think?
Old 08-23-2012, 07:15 AM   #4
Rewards Points: 270
One drawback of not being able to replace the basin is that I can't fit a backup sump pump in there. The size of the opening is the normal 18", but the metal basin severely constrains the space. Any ideas for getting a backup unit in this sump?
Old 08-23-2012, 07:25 AM   #5
Willing to listen
Rewards Points: 223
You might have some luck freeing up space for the backup by switching the primary pump to a pedestal type. This worked in my situation.
Done That is offline   Reply With Quote
Old 08-23-2012, 08:57 AM   #6
Rewards Points: 270
Oops I already bought a new zoeller submerged pump. It looks like there are pedestal backup pumps out there, I'll try that, thanks!!
water level equalizing in sump pump basin? dmp Plumbing 21 04-13-2012 06:42 PM
Sump Pump Basin install, existing rough sump hole. McSweny1103 Building & Construction 3 02-12-2012 02:45 PM
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 08:05 AM
Sump Pump Basin jonathan123 Plumbing 2 08-21-2011 08:31 PM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 04:30 AM
