Summer Vacation - Water Heater Turned Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2012, 09:29 PM   #1
Rewards Points: 119
Summer vacation - Water heater turned off
Hi,
I will be away for 1 month this summer and I will switch the main breaker off.
I wanted to know if I need to drain my water heater in addition to close the cold water supply.
When I come back, do I just need to open the cold water supply and turn the heater on or is there anything else I need to look at?
My heater is this one and by default it is set to 140F, in order to avoid any risk of legionnaires disease, should I wait at least 1h and then open the hot water and let it run for some minutes?
Alex
Metallo is offline   Reply With Quote
Old 05-21-2012, 09:52 PM   #2
Ravenworks's Avatar
Set it to vacation mode on the thermostat.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-21-2012, 09:59 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I chuckled when I saw you mention legionairre's disease. I did some pretty extensive research on that during my apprenticeship, and concluded that it is nearly IMPOSSIBLE to catch it from a water heater.
If you're leaving during warm weather months, I wouldn't worry about draining it.
Shut off the cold water inlet to the water heater, and relieve the pressure off of the system.
For that matter, i'd recommend shutting off the water to the entire house.
It sounds from your description that you have an electric water heater?
Journeyman Plumber
Old 05-21-2012, 10:04 PM   #4
Originally Posted by Metallo View Post
Hi,
Alex
I have a hot water heater at my cottage that is identical to yours. I just turn off the breaker when I leave and flip it on when I return. have been doing so for 30 years.
There is more danger from a burst water line causing a major problem.
Always be sure to shut the water main off when going on vacation.
Old 05-21-2012, 10:08 PM   #5
Rewards Points: 119
Originally Posted by Alan View Post
I chuckled when I saw you mention legionnaire's disease. I did some pretty extensive research on that during my apprenticeship, and concluded that it is nearly IMPOSSIBLE to catch it from a water heater.
Yes, it is an electric water heater.
I will shut off the water in the entire house for sure.
Regarding the legionnaire's disease, I am originally European and we have a proverb which in English is: an ounce of prevention is worth a pound of cure'
Thanks!
Alex
Old 05-21-2012, 10:17 PM   #6
Rewards Points: 1,448
I suggest turning off the water heater heat before the water is shut off.
The water heater heat must be shut off before the heater's tank is drained.
Water should be gushing from an open hot faucet before the water heater heat is turned back on.
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 04:41 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
