Suggestions To Long Horizontal Run Problem... - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2007, 07:23 PM   #1
Rewards Points: 150
Suggestions to long horizontal run problem...
I just realized this is the perfect place to ask about ideas for this intermittent problem I've been having. My house is built C 1960, so it's a bit older home with older drainage systems.
The problem I have is that the sink drains into a 2" stack towards the basement, then enters the concrete. At this point, it travels about 50 feet horizontally to the main stack. Every so often, the horizontal run get's clogged and backs up all the way upstairs. As this is vented, I can't plunge at the sink.
I've since added a drain clean out downstairs that when this happens, I stick a 50 feet snake into the horizontal run and that cleans it up.
What I've wondering is if there are any tricks that anyone here knows of that can keep this drain cleared, short of breaking concrete and putting in a 3" line.
The other added issue is that there's a garburator/garbage disposal in the sink, it's 1 hp Insinkerator... maybe it doesn't grind fine enough?
slakker is offline   Reply With Quote
Old 08-01-2007, 09:01 PM   #2
Is there any trees in the yard where this line is buried?
redline is offline   Reply With Quote
Old 08-02-2007, 02:05 AM   #3
Rewards Points: 150
Nope... it's all under the basement floor... No big deep rooting trees anywhere close by...
Everytime it clogs, it does seem like it debris from the garburator. I just don't want to accept the only solution is to not use garburator...
Old 08-02-2007, 08:34 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Clean the line out with cutter blades, to the full size bore of it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-02-2007, 08:52 AM   #5
Rewards Points: 150
Is a cutter better than using "hydro scrub"... my wife had the Rooter guys come in the first time this happened and they did one of those hydro-scrubs with presurized hot water and their "enzyme" product. I'm been skeptical whether this had any long term benefits...
Old 08-02-2007, 08:54 AM   #6
Journeyman Plumber
How long ago?
Old 08-02-2007, 08:57 AM   #7
Rewards Points: 150
We did first when we moved in about 3 years ago, but it clogged up about six months after. It's happens every 6 to 9 months it seems... and I snake it myself now, but haven't rented a power snake with cutter yet...
Old 08-02-2007, 09:35 PM   #8
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
Water jetting blows a hole through a clog, a spring cutter cleans off the walls of the pipe. Snake the line out with a spring c cutter and make sure you turn water on before the disposal and let it run a bit after, throw a kettle of boiling water down there every other week or so just to keep oils and grease from foods moving. An enzyme cleaned wouldn't hurt to use now and then either.
Internet Electrical Critic
Trump Enthusiast
MechanicalDVR is offline   Reply With Quote
Old 08-03-2007, 01:45 AM   #9
Rewards Points: 150
Thanks... I've been using the enzyme cleaner and have noticed that I haven't had a clog in almost a year... so I'll keep my fingers crossed...
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 02:06 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 08:16 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
