Suggestions On Correcting This Laundry Room Plumbing Problem. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2010, 09:53 PM   #1
Rewards Points: 153
Suggestions on correcting this Laundry room plumbing problem.
These 2 photos are what I am currently dealing with.
I am working on the water in the basement, so this is not connected at the moment.
I was planning on pushing the box back into the drywall and correcting the drain. Also tap in for a small laundry sink.
BUT the vent pipe is directly behind this box, and moving to the side is out due to studs.
So I thought I could frame in a box and then correct the drain.
I am assuming I should not mess with the vent? It is required?
theedudenator is online now   Reply With Quote
Old 02-15-2010, 09:58 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The way that is plumbed is not even CLOSE.
Why can't you put it in the wall? You can drill the studs you know. We do it all the time.
it should look something like this when you're done. http://www.askmehelpdesk.com/attachm...n-img_0675.jpg
Vents go on TOP of the trap arm, not below them.
Journeyman Plumber
Old 02-15-2010, 10:07 PM   #3
Rewards Points: 153
I would have to move the vent in order to push this back into the wall.
To keep it centered between the 10" stud center.
unless I can keep the vent inline with the drain.
And 90 degree the vent around the box...
Old 02-15-2010, 10:09 PM   #4
Doing it myself
Alan's Avatar
Why can't you move the box to the left or to the right?
Journeyman Plumber
Old 02-15-2010, 10:17 PM   #5
Rewards Points: 153
Ok,
So I can move it to the next stud opening which would place it directly behind the washer machine
I need to see what the wall has behind it.
Old 02-15-2010, 10:21 PM   #6
Rewards Points: 153
That does not look so good.
The next stud opening over is the main run for all my electric on the 2 floors.
If I go towards the left (the dryer)
There is a tripple stud in the way.
So I would need a 2" hole through 3 studs to run the drain pipe.
Old 02-15-2010, 11:10 PM   #7
Rewards Points: 153
I made some room with my sawzall
What you see in the wall is the vent.
I need to put the drain close to this location inside the wall.
So I can just relocate the vent to sidestep the drain.
I need to find an example of a drain and vent close together.
I am assuming the vent must tie in above the washer drain?
If it is below it would be a wet drain.
Old 02-15-2010, 11:25 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
whoever did that origionally should be beaten with his own tools,then his tools should be buried where they can no longer harm plumbing!
plummen is offline   Reply With Quote
Old 02-15-2010, 11:40 PM   #9
Rewards Points: 153
This past weekend I ripped ALL the plumbing out of the basement.
Started from scratch. Things are getting better!!
I found half size outlet boxes. This will fit in the stud cavity.
Old 02-16-2010, 10:17 AM   #10
Doing it myself
Alan's Avatar
we NORMALLY drill studs to accomodate an C/W box. There's not enough room in a 16" stud bay to accomodate the p-trap and the C/W box without crossing over the water lines (which is a pain in the rear end)
Is that a 2x4 or 2x6 wall? Do you know why that stud is tripled up? If it's tripled for structural reasons, you might not want to touch it anyway.
Journeyman Plumber
Old 02-16-2010, 10:29 PM   #11
Rewards Points: 153
No clue why it was tripled.
I think I found a way to make this work without cutting studs.
On the left is my vent. I did not cut the extra pipe yet.
On the right is my 2" drain.
Top is for the washer and bottom is for the sink.
Can I exit the fitting at an angle out the wall? So I can clear the washer and aim for the center of the sink?
Directly under the floor will be a 2" P trap for the drain.
6-12" after this will be the T for the vent (under the floor)
Old 02-16-2010, 10:38 PM   #12
Doing it myself
Alan's Avatar
That would so not fly around here, nor would it in any area in the united states that I know of. Maybe if you moved to somalia?
No P-trap for clothes washer shall be roughed in below the floor, but shall be at least 6" but no more than 12" above the floor. Any standpipe for a clotheswasher shall be no less than 18" in length, nor shall it be more than 30"
What you've done there to attach the sink is called "wet-venting".
What you're doing is turning the vent for the laundry sink into a drain. I can't recall the exact wording because it's a big paragraph, but basically you'd have to have a minimum 2-1/2" line coming up below the drain for the laundry sink.
Without some sort of diagram and dimensions etc, it would be hard to direct you further, especially considering your pictures are fairly close-up, and hard to take in the entire size of the room/area you want to install this stuff in.
Journeyman Plumber
Old 02-16-2010, 11:35 PM   #13
Rewards Points: 153
So I could Tee the vent between the sink and laundry box?
What is the problem with having the P trap under the floor?
what problem does this cause?
Old 02-17-2010, 12:37 AM   #14
Doing it myself
Alan's Avatar
No.
Distance between inlet and vent becomes too long, trap siphons, sewer gas enters home, people get sick. It needs to look something like the picture I posted. There are MINOR variations that would work, but that is the basic standard.
Journeyman Plumber
Old 02-17-2010, 12:52 PM   #15
Rewards Points: 153
I am attaching a sketch.
What if I used a double wye?
Laundry room remodel RegeSullivan Remodeling 3 02-08-2010 04:56 PM
Laundry room plumbing mikev88 Plumbing 1 01-01-2010 04:10 PM
Washer and Utility sink in a room that has never had plumbing mattreyno Plumbing 1 12-28-2009 10:22 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
