Sudden Change In Water Temperature To Hot - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2008, 12:08 PM   #1
sudden change in water temperature to hot
Just in the last couple of days have noticed that hot water is getting extremely hot. have one valve shower head and have to turn it to cold side to get warm water otherwise hot burns. Checked other faucets and hot is really hot; much hotter than normal. Two of the other faucets are one valve/handle and the other is two handle. Doesn't appear to be any leaks that we can find easily. Thermostat in hot water heater? Need help!
rolittleton is offline   Reply With Quote
Old 12-29-2008, 07:58 AM   #2
Registered User
Termite's Avatar
Assuming no adjustments have been made to the temperature setting of the water heater? There could be something keeping the burner on in the water heater. I'm no good at water heater guts but I'm thinking thermocouple.
Old 12-29-2008, 08:17 AM   #3
Fixed hot water heater!
Thanks for reply. Did some more troubleshooting and found it was thermostat. Got replaced in short time and everything working great now! Love this forum!
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
