Old 10-10-2008, 02:27 PM   #1
Such thing as 3"x3"x-1/2" ABS Y?
Hello.
Is there such thing as a 3"x3"x1-1/2" ABS Y "Black"? I need to tie in my new tub drain into the 3" line. I know I can get 3"x3"x2" Y but I cant find the 1-1/2". Could I just go with a 2" Drain line for my tub or do I need to get a 2" to 1-1/2" Reducer to go to the tub drain kit?
mfleming is offline   Reply With Quote
Old 10-10-2008, 02:44 PM   #2
DIY'r
ScottR's Avatar
Would this work for you?
http://plumbing.hardwarestore.com/52...ye-685164.aspx
Or this?
https://www.hardwareworld.com/3-X-1-...e-pEC0RO4.aspx
If your tub drain kit is 1-1/2", there's no harm in using a reducing coupling to bring it up to 2" before it meets with the 3". That way at least you wouldn't have to wait for a UPS delivery.
(BTW - I've never shopped at either of the above sites before, so can't comment on whether you should use them).
Edit:
It can't hurt to go 1/2" bigger if your drain kit can connect directly to 2".
ScottR is offline   Reply With Quote
Old 10-10-2008, 04:12 PM   #3
Moderator
Termite's Avatar
You can use a 2" to 1-1/2" bushing to reduce without adding length.
Changing from 1 1/2" PVC to 2 1/2" PVC DLHC40 Plumbing 4 06-30-2008 11:39 AM
Is this thing safe? possible fire hazard? santawatt Electrical 3 06-25-2008 11:05 PM
Bryant 394G Blower Motor - How do I lubricate this thing? JohnCoffey HVAC 2 06-19-2008 09:05 PM
Is there such a thing? wiscborn Plumbing 6 06-29-2007 03:19 PM
1/2" breakers Clutchcargo Electrical 3 06-22-2007 07:28 AM
