Old 01-18-2009, 08:56 PM   #1
WaldenL's Avatar
Talking
Success - Rerun Laundry Room Gas
I want to thank the general "group" here for all their help, both answering questions and providing a history I could look at of past questions. Gas pipe is run to second floor, passed the "pressure test" (20lbs 20 minutes) and also the bubble leak for the parts I couldn't pressure test. All is good in the world, and I can take a warm shower!
Thanks everyone!
WaldenL is offline   Reply With Quote
Old 01-18-2009, 09:10 PM   #2
Moderator
Termite's Avatar
Thanks for saying thanks. I'm sure that the folks that helped you out certainly appreciate it! Glad to hear it worked out for you.
Old 01-23-2009, 12:06 AM   #3
pressue test but still pass but had to check 4 still leak i dont understand ???
drunknmaster is offline   Reply With Quote
Old 01-23-2009, 12:35 AM   #4
Moderator
Termite's Avatar
As an apparent plumber I'm sure you know that you can't pressure test gas connections to the appliance and commonly people close the shutoff valve for the air test. Therefore a soapy water test of those untested fittings is incredibly prudent.
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 11:08 AM
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 08:08 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 11:35 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
