Submersible Well Pump Running All The Time - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2011, 12:04 PM   #1
Submersible well pump running all the time
Having an issue with low water pressure so I swapped out the pressure switch. Still have low pressure around 25psi which never allows the pump to shut off. Obviously I have a leak somewhere or the pump is going. I have had this pressure issue for about a month so I am suspecting it has been running non stop. Also when I cut the power I lose water in my system leading me to believe the foot valve is bad or a leak in the well line. Does this sound right before I pull the pump?
ppandr is offline   Reply With Quote
Old 03-20-2011, 12:08 PM   #2
Water Treatment
Rewards Points: 900
From what you are saying and from what I have learned from the well drillers in my area ... you are on the right track.
Could be a bad foot valve or even a break in the line between either the pump and pitless or between the pit less and the house.
Akpsdvan is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Freezing coils on heat pump - fan not running Tomcw HVAC 5 01-15-2011 09:02 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Sump Pump Gets Stuck in Running Position sweaty Plumbing 2 04-09-2009 06:35 AM
AC Unit Running All The Time Data Captured... GeorgeCJ HVAC 4 07-24-2008 08:36 PM
