Old 07-08-2010, 02:07 PM   #1
Professional Wood Shafter
ryanh's Avatar
submersible well pump . first start.
Hello
I installed my submersible pump in the well and property wired the control box and the pressure switch and have the plumbing setup to the pressure tank. The pump is a 1/2 hp 3 wire submersible pump. The manual doesn't say anything but is there anything special required for starting the pump the first time? Should i just flip the breaker and the pressure switch/gauge shows 0psi so in turn should turn on the pump until the pressure cut off?
ryanh is offline   Reply With Quote
Old 07-08-2010, 02:39 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Assuming it works properly when you turn it on, I'd measure current draw so you have a baseline measurement for your brand new pump. You can expect about 3 A @ 240v.
Old 07-08-2010, 04:33 PM   #3
You said three wire??
Could there be four??
If there is really just three you would not use a control box.
There is BIAC in the pump.
That is why I never use control boxes.
They are out dated.
Mr. Green is offline   Reply With Quote
Old 07-08-2010, 09:17 PM   #4
ryanh's Avatar
Ya Control box, 3 wire+ ground (4) ..
Old 07-08-2010, 09:31 PM   #5
Licensed Master Plumber
Flip the switch and Get er Done
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-09-2010, 07:48 PM   #6
ryanh's Avatar
Hah check this.
Took the ohm readings and they all were all good, pulled the pump anyways, notice the metal cover at the bottom of the pump was kinda loose took the screws off and NO MOTOR. LOL
Old 07-09-2010, 09:09 PM   #7
Yoyizit's Avatar
Originally Posted by ryanh View Post
Hah check this.
Expect low current draw.
Old 07-10-2010, 01:56 AM   #8
ryanh's Avatar
Actually all the current readings at the control box were normal readings..
Old 07-10-2010, 02:07 PM   #9
Not sure I'm following this; where did your motor go?
bob22 is offline   Reply With Quote
Old 07-11-2010, 07:15 PM   #10
ryanh's Avatar
i guess it fell out of the casing from the bottom and down the well, and then someone did a swap and returned it and I got stuck with it
Old 07-11-2010, 10:42 PM   #11
nap
You talking to me?
nap's Avatar
You're serious? I thought you were kidding.
Have you called the supplier and asked them how they are going to get their defective pump out of your well?
or do you mean there never was a motor in what you had bought. If so, how did you get "normal" current readings? No motor means no power consumption which means no current flow.
Old 07-12-2010, 10:26 AM   #12
ryanh's Avatar
Im not sure if it was the whole motor, but when i looked up into the bottom of the pump casing it was just hallow up till the intake screen in the middle ..
pitless adapter for submersible pump hookup ryanh Plumbing 2 04-29-2010 09:41 PM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Well pump noisy, tripping overload. lennyjay Electrical 2 07-07-2009 11:47 AM
power to submersible well pump erlindbl Electrical 24 02-08-2009 10:17 PM
