Submersible Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2008, 12:58 PM   #1
Submersible well pump
Can I disconnect the main from the pressure tank to the well pump with out worrying about losing the prime?
Thank you in advance.
mark942 is offline   Reply With Quote
Old 02-26-2008, 04:25 PM   #2
electrical contractor
Rewards Points: 150
Mark,
You can do whatever you want to the piping, a submersible pump does not lose its prime due to it being under the water.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-27-2008, 04:45 AM   #3
Thought as much,just wanted to make sure.Had a above ground once that had me running in circles.
Herd once that the silliest question was the one that wasn't asked. Thank you............
sump pump issue mikehende Plumbing 15 02-15-2008 07:36 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
intermatic timer with submersible water pump bardos Electrical 2 09-02-2006 02:41 AM
