Submersible Pump Or Pressure Gauge - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2013, 05:59 PM   #1
submersible pump or pressure gauge
I have a submersible pump in a reservoir, the reservoir has plenty of water. I have a pressure tank set at 30/50, I have watched it run through some cycles. It first comes on at 30 then cuts out at 50, next time it comes on at 25 and cuts out at 45 and then the next time it came on at 25 and then quit at 40, I noticed that after 1 minute it resumed pumping up to 50 and stopped. I realized that the pressure gauge contacts had still been closed but the pump had stopped pumping and then rested or cooled and then finished pumping up to where it was supposed to cut out. The pump does have a thermal switch but it is in a large reservoir of 50 degree water. What is happening?
Henry M Hobson is offline   Reply With Quote
Tags
gauge , pump
well pump pressure without the prime plug? sawduster Plumbing 11 12-19-2012 06:48 PM
Submersible pump wiring? Master Brian Electrical 15 05-08-2012 12:20 PM
Submersible well pump pressure tank? kyle79 Plumbing 2 04-10-2012 05:44 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 08:53 PM
Intermittent Low Pressure, "Sluggish" Pump Sound, Well wcp Plumbing 3 06-27-2010 03:50 PM
