Submersible Pump Hook Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2009, 07:32 PM   #1
learning
submersible pump hook up
Hello, I have a cottage next to Lake Huron in Ontario located on solid limestone. I recently had an 80 ft well dug with flow in excess of 20 gpm. Problem is, that on solid limestone it is not practical to dig down below the frost line. Has anyone had this problem? It is a seasonal cottage and is only used for about 4 months during the summer, not insulated, so all the water lines are drained. Is there a system designed where water can be drained back down to the water level in the well, some kind of relief system that would allow drainback when valves are opened and the pump shut off? The cabin is slightly downhill from the well, so draining those lines would be easy, just need to lower the water from the pitless adapter down to the water level in the well. In the spring, would that valve automatically seal under pressure? Wondering if such a thing exists. Any comments certainly appreciated. Thanks.
Ken0217 is offline   Reply With Quote
Old 03-17-2009, 07:59 PM   #2
the Musigician
DangerMouse's Avatar
we use these around here...
http://plumbing.hardwarestore.com/52...-hydrants.aspx
should do the trick, or at least help point you in the right direction?
DM
Submersible Pump lifting pumplifter General DIY Discussions 5 09-13-2009 09:45 PM
Pitless Adapter Submersible Pump Wild Blue Plumbing 5 08-31-2009 02:02 PM
power to submersible well pump erlindbl Electrical 24 02-08-2009 10:17 PM
intermatic timer with submersible water pump bardos Electrical 2 09-02-2006 02:41 AM
