Subfloor Fix And New Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2012, 11:37 PM   #1
Subfloor fix and new flange?
I have to replace a flange and some 3/4 plywood around an upstairs toilet. It is a 4" ABS pipe with an ABS/plastic flange. How do I replace the flange/sleeve? Can I insert a flange/insert into the existing pipe or will the smaller size "bottleneck" the toilet waste?
Thanks, Tom
Picture:http://www.flickr.com/photos/5436129...in/photostream
Would this work? Does the flange sit FLAT on the new 3/4" plywood?
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
trmoore2 is offline   Reply With Quote
Old 07-03-2012, 12:17 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 924
Thanks, Tom
If you have the room, I'd cut back on the horizontal line- put on a coupling, new 90 and flange
The Following User Says Thank You to TheEplumber For This Useful Post:
trmoore2 (07-03-2012)
Old 07-03-2012, 12:23 AM   #3
What is the "horizontal line? And why isn't a 4 x 3 "sleeve" sufficient?
Like this:
Thanks, Tom
Old 07-03-2012, 12:28 AM   #4
Renovations contractor
Bonzai's Avatar
He's referring to the horizontal part of the drain.
It's never good to reduce the inside diameter of a toilet or other drain.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
The Following User Says Thank You to Bonzai For This Useful Post:
Old 07-03-2012, 01:41 AM   #5
If the opening at the bottom of the porcelain toilet is only 2 1/4 inches, what difference would 1 inch of 3" pipe make? The new "sleeve" is still bigger than the toilet (bottom) opening, and then after an inch or two, the pipe is back to 4 inches. I'm not a plumber, but it seems like the sheer gravity and expanding diameter of the passage would never be a problem.
Old 07-03-2012, 08:56 AM   #6
Plumber
Rewards Points: 924
According to UPC code, a reduction of pipe size from 4" to 3" at a closet flange is acceptable.
However, the method you want to use is not good - never seen a good plumber use your method either. and it's a lot more difficult then what I suggested.
Old 07-03-2012, 10:20 PM   #7
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
kind of a old trick of mind cut the closet bend just below were the very bottom of the flange ends get another 4" flange abs NOT a adjustable metal ring type cut the flange approx in 1/2 you will have a coupling and the rest of the flange glue the coup on the closet bend lots of glue allowing enough for you to glue a piece of 4" that u measured top of closet bend after cut to top of finish floor then glue pipe into coup then the flange make sure you secure flange w/brass screws all the holes ,highly recommended let cure 24 hours never had a problem yet, i'm sure i'll hear some sh....t but works like a champ when needed.
wctekkk is offline   Reply With Quote
The Following User Says Thank You to wctekkk For This Useful Post:
TheEplumber (07-03-2012)
Old 07-03-2012, 10:25 PM   #8
Plumber
Rewards Points: 924
Nice trick
Curious- why not adjustable ring- rust or another reason?
Old 07-03-2012, 10:41 PM   #9
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
after cutting flange not saying it doesn't work but the metal ones become much more flimsy.
