Sub Pump Line Frozen Outside - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2011, 04:42 PM   #1
Sub pump line frozen outside
Ive finally got all the ice out of the line took all the old insulation off the pipe and installed a frost king water pipe heat cable on my sub pump line out side and insulated 10' from the house out. Know theres is 6' of pipe with exposed water pipe heat cable, on my sub pump line outside is this ok. I guess my question is can you leave the frost king water pipe heat cable exposed to the elements or should i go and insulate the whole subpumb line out side?
LOUSY CARPENTER is offline   Reply With Quote
Old 02-13-2011, 08:53 AM   #2
Rewards Points: 1,506
Unless the heating cable instructions say otherwise, the pipe, cable and all, needs to be covered with insulation. Otherwise the heat from the cable will go off into the atmosphere.
Any vertical or nearly vertical part outdoors coming up from the pump pit and above the frost line must be heated. The horizontal or nearly horizontal part above the frost line should be heated, and if there are any dips (also called bellies) or even long perfectly horizontal portions where water may collect, must be heated.
AllanJ is online now   Reply With Quote
Frozen Hot water line Jimmie Dale Plumbing 1 02-02-2011 01:45 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 11:27 AM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 07:42 AM
