Styrofoam Bottom On Bathtubs - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2013, 04:09 PM   #1
Rewards Points: 248
styrofoam bottom on bathtubs
My acrylic bathtub came with styrofoam on the bottom (common these days). The floor is just slightly off level. I built a cradle out of 2x4's. The cradle is perfectly level. Only problem is on one side of the bathtub the styrofoam touches the floor on the other side it is ever so slightly (1/8-1/4 inches) in the air. I could apply thinset to the plywood. Someone told me not to do that because the thinset will crumble and will not attach onto the plywood well. I was told to put a 1/4" piece of backer board under the styrofoam on one end instead. Has anybody had experience with this type of situation and can tell me which is the best solution of the two and what are the consequences of doing it one way or the other? Perhaps there is a third better solution?
jackwashere is offline   Reply With Quote
Old 10-30-2013, 04:44 PM   #2
Rewards Points: 14,000
If thin set would crumble why would it be used under tile backer and under tile?
gregzoll (10-30-2013)
Old 10-30-2013, 05:26 PM   #3
Rewards Points: 248
I want to use it under styrofoam under a bathtub. Will it crumble over time as people get in/out of the bathtub?
Old 10-30-2013, 05:45 PM   #4
Rewards Points: 6,652
Use Self Leveler under the space that you are placing the tub. Once you place the tub in there, while it is still wet, it is not going anywhere. The other option is to use a thin layer of Great Foam, and then set the tub in it, before it sets up, and be done with it.
Other option is to place some 1/8"-1/4" plywood shims under the tub to even out. My guess is that they placed the Joists Crown down in that area, or the house foundation settled in that area. How old is this house, and can you post some pictures from below the bath and the bath area, showing what you are dealing with.
Old 10-30-2013, 07:31 PM   #5
Rewards Points: 248
You mean Great Stuff?
That's an idea! $4 bucks. It would bond well with styrofoam and work its way in under the tub.
Old 10-30-2013, 07:44 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 812
Be careful it doesn't expand and lift your tub.....
Old 10-30-2013, 07:53 PM   #7
It expands to much and will compress when stood on. Not a great idea to use foam.
Old 10-30-2013, 07:58 PM   #8
Not really, depending on which version you use. No different then the foam block that is underneath the tub attached to it.
Old 10-30-2013, 08:59 PM   #9
Rewards Points: 248
Good point. Foam gets spongy. Styrofoam is hard and different than Great Stuff and other similar foams. Thanks for the suggestion however.
I think I'll just install backer board onto the plywood and apply a layer of self leveler or thinset (the other option you mentioned) on it then rest the tub on that. I will have to raise the cradle by 1/2" to compensate for the 1/2" backer board. It seems like the best safest option.
Old 10-30-2013, 09:07 PM   #10
Rewards Points: 42
You can get hardibacker in 1/4. It will save you from raising the whole tub. Raising the whole tub may impact your floor and how it meets the tub.
Dan
djlandkpl is offline   Reply With Quote
Old 10-30-2013, 09:56 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Mix up some plaster and trowel it out where the tub will be sitting
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Davejss (10-31-2013)
Old 10-31-2013, 09:39 PM   #12
Davejss's Avatar
Rewards Points: 776
Yup. That's the way its been done for the last ......years.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
plummen (11-01-2013)
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Rotten bottom plate & studs. (Photos) JustADoc Building & Construction 24 08-10-2011 09:01 PM
Rotten Stub and bottom plate against exterior wall markx Carpentry 2 05-26-2011 11:51 PM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Bottom of drywall jessica042785 Drywall & Plaster 3 02-15-2010 10:11 AM
