Stupid Water Heater! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2007, 07:30 PM   #1
stupid water heater!
can anyone help. my husband and i are trying to replace the prv on our stupid water heater. But we can't get the old one to come off. My 240 pound husband was hanging from the pipe wrench and the thing still won't come unstuck! is there a trick to it?
zoemommy is offline   Reply With Quote
Old 11-29-2007, 07:38 PM   #2
Send a message via AIM to Marlin
What size pipe wrench are you using? How old is the heater? Do you have hard water in your area?
Those valves should pop off with very little effort.
Marlin is offline   Reply With Quote
Old 11-29-2007, 07:40 PM   #3
it's a 10 grip pipe wrench. the water heater is 15-20 years old.
Old 11-29-2007, 07:40 PM   #4
and yes we have hard water!
Old 11-29-2007, 07:52 PM   #5
A good run for a water heater is ten years so this thing is living on borrowed time. The hard water will also have caused the valve to seize in place. It probably can be moved however a 10in wrench is next to useless for this. I would normally use a 24in, maybe an 18in. If you don't have another wrench I would recommend putting a pipe or something over the handle to get some more leverage but what brand is the wrench? If it isn't Ridgid or Lenox you may end up snapping or bending the wrench possibly injuring yourself in the process. One thing you could try is using the drip leg to get some leverage and move the valve. Don't pull it too hard though as you don't want to bend it.
Old 11-29-2007, 08:00 PM   #6
ok we'll try that. would p b blaster help?
Old 11-30-2007, 06:13 AM   #7
If you have PB blaster give it a try. I don't believe the stuff does what it claims but some swear by it. Let us know if it came off. Or is it new water heater time?
Old 11-30-2007, 10:38 AM   #8
Rewards Points: 150
Just a note: if the thread has seized real bad, aplication of more leverage might:
a. snap off the threaded portion off the PRV
b. mangle the thread of PRV socket on the heater.
Either way, it'll be new heater time. Which it is already anyway - 15-20years on hard water puts this one on its last legs.
scorrpio is offline   Reply With Quote
Old 11-30-2007, 04:04 PM   #9
That's what I got at in the first post. Try and turn the thing, if it breaks off, it was time for a new heater anyway so you aren't any worse off.
Old 11-30-2007, 04:15 PM   #10
Journeyman Plumber
Ron The Plumber's Avatar
An 18" pipe wrench and hammer does wonders.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-30-2007, 09:03 PM   #11
Eibwen
The question I have is WHY are you replacing the PRV??
If its blowing water, its probably a sign of overheat/failure anyway.... And with the age noted its probably time for a new tank.
Sammy is offline   Reply With Quote
Old 12-01-2007, 07:19 PM   #12
thanks
thank you to every one for the advice!
the p b blaster worked! I was amazed, personally. we're still not getting enough hot water, but at least it's not pouring on the floor now. if we can get 3 more months out of this one it'll have been worth the aggravation! Also, the bigger pipe wrench worked wonders too. my hubby said screw it, this stupid wrench isn't workin! I'm goin to lowe's. 40 minutes later, the prv was replaced and no more leak!
Thanks so much guys.
Old 12-01-2007, 07:24 PM   #13
You're giving the PB Blaster a lot of credit that the larger pipe wrench deserves.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
