Old 05-08-2007, 08:58 PM   #1
Default Stuck shower head
I am trying to install a new shower head but the old one is stuck. I've removed the shower head itself but there is a ball nut that allowed the shower head to swivel attached to the pipe from the wall that will not come off. I have tried WD-40 but it will not come off. The shower head was installed in the early to late 70's. It looks as though the ball is a complete second piece, but is it a part of the pipe? Does this ball come off at all or do I have to cut the pipe and go from there? Help!
stealthxcat is offline   Reply With Quote
Old 05-08-2007, 11:19 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The ball is part of the arm, you have to unscrew the entire arm out of the wall and replace it with a new arm that will have thread on both ends.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
More On This Topic
Sometimes a standard shower head just doesn't do enough. It can't be maneuvered into the right position when someone with a broken arm can't get their cast wet. It can't reach the corners when you clean the tub. It can't rinse all the soap out of Fido's... Read More »
Hi, I'm Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, today I'll show you how to clean a shower head. If the shower head in question happens to be a recently built apartment or house, mineral build-up may not be the problem at all... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can visit blackdogvideo.biz on the internet. Okay, we... Read More »
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can visit blackdogvideo.biz on the Internet. Adjusting... Read More »
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 04:58 PM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 09:39 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 11:05 AM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 08:30 AM
Shower head compatibility (complete novice) jnod Plumbing 1 10-26-2005 10:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
