Stuck Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2010, 11:17 PM   #1
Stuck shower head
Please help,
My shower head is completely stuck. I've tried using WD40 and a boa. I've also tried using an adjustable wrench. Yes, I'm turning counter-clock wise, but it won't budge.
This is the boa I tried to use:
jivey80 is offline   Reply With Quote
Old 04-10-2010, 11:37 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
try a better pipe wrench,maybe a little heat
plummen is offline   Reply With Quote
Old 04-11-2010, 11:12 AM   #3
biggles's Avatar
take a pipe wrench and tape the claws(won't scare the supply out of the wall)..thats your hold back.then the channel locks is the CCW force get the wrenchs as close as possibble to the threads shower..set that hold back pipe wrench so it is tight >>> push test CW now that channel locks and jerk it CCW right on that shower head should loosen up try to get your knuckle just opposite each other in front of your face..standing in the tub as you grab both ....... if you have 2 pipe wrenchs better for that CCW head fitting
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-24-2010 11:31 PM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 06:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
