Stuck Shower Faucet Handle (Delta) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2010, 12:49 PM   #1
Post
Hey all,
I'm trying to replace my Delta shower head and handle. I got the screw off that holds the handle, but it's not budging. Any ideas?
Thanks in advance.
Stuck Shower Faucet Handle (Delta)-img_5981.jpg   Stuck Shower Faucet Handle (Delta)-img_5982.jpg
Jeoroc24 is offline   Reply With Quote
Old 03-03-2010, 08:44 AM   #2
If you removed the little hex set screw, then the only thing holding it together is mineral deposits that have built up over time. The only way to break it free is with minimal knocking on it and working it loose. I don't know of any magic tricks to get it apart. Good luck,
Mark
Mark Rhein is offline   Reply With Quote
Old 03-03-2010, 08:58 AM   #3
Thanks Mark.
I was a bit worried about breaking it off. After reading your comment, I rocked the handle slightly back and forth. A couple of minutes of this and the handle came off. Those mineral deposits make a pretty decent adhesive.
Thanks again for your prompt response.
Old 03-03-2010, 10:11 AM   #4
Glad it worked out for you.
Mark
Tags
shower
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Delta Shower Faucet and Valve- plummer botched? twanto Plumbing 3 08-08-2009 08:04 PM
One Handle Shower Faucet GLASSMAN1 Plumbing 3 02-09-2008 03:08 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 08:08 AM
