Stuck Set Screw - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2011, 08:38 PM   #1
stuck set screw
Any ideas on how to remove a frozen shower handle set screw on a delta faucet
eric8221 is offline   Reply With Quote
Old 03-24-2011, 09:15 PM   #2
Rewards Points: 352
If you haven't stripped the head spray with PB Blaster or Rustbuster and let sit. Try again tommorrow
plumberinlaw is offline   Reply With Quote
Old 03-25-2011, 08:30 AM   #3
I actually had to figure this problem out just last week. I took a 1/2" metal drill bit in my drill and drilled the head off the screw. Then the handle slid right off, and I could get pliers on the screw and screw it out. Of course the screw was brass, so I am assuming your screw is brass also, if it is stainless or even steel it would be much more difficuly to drill out.
broox is offline   Reply With Quote
Old 03-25-2011, 04:04 PM   #4
Rewards Points: 1,216
" I second that with additional thing to do shut the water off to the shower turn the handle so the set screw is facing up fill the hole with the stuff plumber recommended. let it soak all night."
COLDIRON is offline   Reply With Quote
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
