Stuck Iron Pipe On Oil Tank Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2009, 09:27 PM   #1
stuck iron pipe on oil tank vent
Hi all,
I need to clean the overflow whistle on my tank. The vent pipe was plumbed probably in 1961 when the house was built and is all iron. Using a 16" pipe wrench I have been unable to budge the large nut where the pipe comes into the tank.
A little description since I can't find my camera-
The vent pipe is attached to the tank body with a large nut and rises 6" to an elbow, then a short section of horizontal pipe to another elbow, then pipe out through the basement wall. The horizontal section between the elbows confuses me because I don't know what kind of tool you could use to turn the pipe in the elbows.
But really the problem is the nut on the tank body. I used a wire brush to remove the paint that the previous owner put on, then sprayed penetrating oil on. No movement after after an hour. What's the best way to break this connection?
I could borrow a heat gun from work and try that. I don't want to take a hacksaw to the thing because of sparks around 250 gallons of heating oil.
Ideas?
Thanks a bunch,
Tim
wrybosome is offline   Reply With Quote
Old 01-13-2009, 09:55 PM   #2
biggles's Avatar
i think that NUT your talking about is a UNION if it is you need to double wrench there.put a (A)wrench on the top pipe going into the union(as .close to this union but not on it as possible) as if you were going to turn it CW....then put another (B)wrench on the union as if you are going to turn it CCW pulling it towards you.holding both wrenches on the horizontals.........PUSH on (A) with your left hand ......and PULL on (B) with your right hand.when you set the wreches have them so when you have yor hands on the wrench handles your grips are right above each other as if you stuck your hands out with your fingers in a gripping (fist)position with the knuckles above each other.a quick jerk pull on the B wrench(pressure on A) and the union will snap loose.
Old 01-13-2009, 10:21 PM   #3
Rewards Points: 562
Take two hammers and time your hits to be together. Tap the heck out of the nut all the way around(on opposite flats). Is this a union or a tank fitting?? IF you need more leverage slip a pipe over the pipe wrench handle for a longer cheater,,,still wont budge??
1. Then have somebody do some hammer tapping while wrenching.
2. put handles close enough you can stick something like a crowbar between handles to pry them apart,,,proper wrench placement is imperative!!
never seen the good old tapping method fail YET!!!
4just1don is offline   Reply With Quote
Old 01-13-2009, 10:43 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,...
If you're lookin' at 1 of These,...
You can take it appart as described above,...
If you're lookin' at This,...
You'll have to start at the Other End,+ take it All appart....
Btw,...
A Hacksaw will Never start a Fire with fuel oil,.... Never Ever.....
Septic Tank Vent Pipe ddave23 Plumbing 29 07-18-2011 01:21 AM
how to relocate existing vent for gas hot water tank rdf2026 HVAC 4 09-30-2008 07:38 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
