Old 05-16-2012, 09:39 AM   #1
Veteran Owner Bungler
Stuck Gerber Tub Spout - How to remove?
Hi All,
I am in the process of rebuilding a vintage early 80s Gerber Tub / Shower valve. I have successfully replaced the valve stems and would like to replace the tub spout as well. The water here in Florida is extremely hard and the spout is stuck. There is calcification on the spout as well as inside.
1. Is the spout a screw on - I believe it is.
2. I have tried twisting it off to no avail. Is there any way of loosening it? What about heating the end of the spout (where i suspect the threads are) to loosen?
3. Any help is greatly appreciated.
edwardk77 is offline   Reply With Quote
Old 05-16-2012, 10:29 AM   #2
A "Handy Husband"
rjniles's Avatar
I just put a big screw driver in the spout hole and apply the muscle. Nrver had on not come loose.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
edwardk77 (05-17-2012)
Old 05-16-2012, 10:38 AM   #3
Code05's Avatar
36" pipe wrench.
Bectha it will loosen then!
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Old 05-16-2012, 09:19 PM   #4
Originally Posted by edwardk77 View Post
Hi All,
we grab end of spout with channel locks hold up on spout as to you turn to left....and get with it...
Old 05-16-2012, 09:28 PM   #5
Look on the bootom side near the wall fist. Is there a hole there? If so there's a set screw that needs to be back off before removing.
Old 05-17-2012, 12:01 PM   #6
Thanks all for the replies, this one due to our extremely hard water here in FL was really stuck, getting a bigger hammer was tried but didn't want to twist the outlet pipe in the faucet. I tried CLR - no help, tried Liquid Wrench no help, then I heated the area on the spout where the thread was and then viola it came. Thanks all for the replies!
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 04:12 PM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
Drain gasket and tub spout problems appleaday3k Plumbing 0 09-14-2011 10:27 PM
thread from filter stuck in spout Meyer Plumbing 1 04-29-2011 09:39 PM
Tub Spout Gap??!? Please help. Mayzee1 Plumbing 7 05-07-2007 04:32 PM
