Old 05-19-2010, 04:39 PM   #1
stuck faucet
how to fix a sticky faucet...? the nozzle that water comes out of that goes left or right is very hard to move.
greendale is offline   Reply With Quote
Old 05-19-2010, 08:09 PM   #2
stuck faucet
Assume a kitchen sink faucet? Brand? How old?
Usually you'll have to take it apart, clean mating surfaces where parts rotate against one another, fix any torn o-rings in the faucet arm where it rotates around the stationary part, lube it with plumber's grease and it might be better.
bob22 is offline   Reply With Quote
Old 05-19-2010, 08:33 PM   #3
Leak Master
stuck faucet
If you are talking about the spout. A good rebuild would help. A new set of o-rings lubricated with plumbers grease, would get that thing moving like it should be. The reason I say rebuild is, why bother shutting off the water, and pulling things apart and not take advantage to put all new rings and seals in. If you have a Delta faucet, then a local hardware would have a whole rebuild kit. If another brand then find appropriate kit and rebuild the faucet. Keep in mind, if the faucet is not visually appealing, then maybe its time for an upgrade altogether.
O'Leaky is offline   Reply With Quote
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
Stuck Shower Faucet Handle (Delta) Jeoroc24 Plumbing 3 03-03-2010 11:11 AM
Ice in Cover over Exterior Faucet SPetty General Discussion 13 01-11-2010 04:32 PM
Cartridge stuck in a Kohler faucet Fan in Exil Plumbing 5 05-16-2009 12:53 AM
Stuck with ugly faucet set? sflmom Plumbing 2 09-21-2008 11:11 AM
