Stuck Diverter Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 10:54 AM   #1
Stuck Diverter Rod
Hey Guys,
I've got a real problem. The diverter rod on my shower faucet pulls up VERY hard. The faucet is only about four years old, so I'm baffled as to why this might be happening already and how to go about fixing/replacing it. I'd prefer to just fix it if possible.
I reached underneath the faucet and it appears as though there might be some type of set screw down there holding the faucet in place. Is that my starting point? Do I loosen that screw and start dismantling the faucet? Any and all help will be appreciated!!
crockett3663 is offline   Reply With Quote
Old 07-07-2012, 12:43 PM   #2
Rewards Points: 3,342
Originally Posted by crockett3663 View Post
Hey Guys,
Is this what your talking about,if so yes the set screw is wher you start.
http://www.homedepot.com/Plumbing-Pl...|b|17343593861
Canarywood1 is offline   Reply With Quote
Old 07-07-2012, 12:51 PM   #3
Actually I've got it fixed already...at least for the time being. I made a trip to the hardware store, where one of the employees is a retired gentleman who used to be a master plumber. He instructed me to simply spray some WD-40 in the small hole that the rod passes through, and also from the bottom up through the faucet, let it penetrate for a few minutes and then try working the rod. It worked like a charm. We'll see how long that lasts. He also showed me how to disassemble the faucet to lubricate it more thoroughly if need be.
But thank you for responding!!
The Following User Says Thank You to crockett3663 For This Useful Post:
oh'mike (07-07-2012)
stuck tub faucet shower diverter flyingmachine Plumbing 0 03-25-2012 12:59 PM
removing bathtub faucet diverter xconx Plumbing 6 10-10-2011 12:17 PM
Need help with a stuck shower diverter dcrandall Plumbing 0 12-12-2010 07:11 PM
Shower Diverter questions... dgates12 Plumbing 3 07-29-2010 08:15 PM
Diverter valve does not extend far enough past surround to install chateau knob-help? Justin311 Plumbing 2 08-24-2009 10:05 AM
