Stuck Core In Moen Style Cartridge For Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2010, 07:32 PM   #1
Question
Stuck core in Moen style cartridge for shower
I'm trying to "simply" replace the cartridge in the shower handle area due the ongoing leaking fr the shower head in our old mobile home. I picked up a Moen stylle cartridge fr Ace and proceeded to remove the old one. Problem is i can't get it out. I removed the case by hand, managed to pull that clip up and out and then used the core puller tool to screw in to the core and pull it out but it wont budge. Turning it seems to just grind up the plastic flanges on old core and pulling it...it doesn't move. Is there something else i need to do? Or is it just calcified in there? It has been years. I've poured a bit of CLR on there just now but i don't know if it can permeated where it needs to just by pouring it on the front of the core that's exposed? Anybody familiar in this area? Pls let me know.
Airwrek1 is offline   Reply With Quote
Old 08-16-2010, 06:10 AM   #2
I assume you removed the copper "U" clip??? Sometimes those cartridges are very stubborn, but the puller usually works when just plain pliers and pulling doesn't.
Old 08-16-2010, 10:49 AM   #3
Thanks for replying JB. Yep, i pulled out the clip that removes fr the top. I actually saw a vid where a guy used a tap to thread and then remove the shell of the old cartridge after he pulled out it's center which he referred to as the stem. I haven't been able to achieve that. Roto Rooter told me sometimes the brass body of the cartridge has melded w/ the slot it's in and the prices would be $290 for cartridge replace and $700 for valve replace.
Old 08-16-2010, 01:49 PM   #4
Owner
LateralConcepts's Avatar
You probably just need to pull harder. Brace yourself so you don't land on your butt when it comes.
Also you mentioned picking up a Moen cartridge. It's probably Price Pfister mobile home (common)
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-16-2010, 07:02 PM   #5
I've had success by heating the valve carefully to melt the o rings that are stuck. Use a torch, turn water off and drain lines, and don't catch the wall on fire behind the shower :-)
the_man is offline   Reply With Quote
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
New Moen Cartridge leaks Firemanjl Plumbing 4 07-21-2011 10:53 AM
broken moen bath/tube cartridge M. A. Mendez-Ch Plumbing 1 06-03-2010 01:59 PM
Cartridge stuck in a Kohler faucet Fan in Exil Plumbing 5 05-15-2009 11:53 PM
Stuck Cartridge Moen Single handle wenceslaus Plumbing 2 04-02-2007 06:47 PM
